Shock Oils
Evo
Ohio
Well I just got my DBXL and haven't had a chance to run it yet way to cole here 7 degrees. I was going over it and checking all the nuts and bolts to make sure they are tight and I got to the shocks and notcied that they are SUPER stiff is this really needed? I can push the front end all the way down and it will only rebound about a half inch. Has anyone changed out shock fluid for a different weight if so what did you use with good results.
thanks
That's not the oil it's the pre load on the springs turn the adjusters on shocks the same number of turns on each shock till front arms are level after you push down and let up on car
