Shock Setting Recommendations for Losi T5
Vinny
Hello, Im a newbie, but I cant seam to settl on my shock adjustments for my Losi T5. I moved the rear shocks inward one notch on the A bar and kept the forward shocks on the outer hole of the A bar. The front shock springs are set loser than the rear. Is this a reasonable set up for your basic flat tract. I appreciate your help think you !!!
Are you talking about oval flat track? Left turns only? I think your going to have to go through trail and error to find the right set up for you.
If handling is loose then stiffen suspension. Handling tight loosen suspension. Make one change at a time and keep notes on how each change affects handling.
You can join this oval racers facebook page to get ideas from them or you can try this link for more info.
Good luck (y)
