oh man alva.. were running the hpi hd shafts the fit isnt perfect, but many of us are running it with no problems. all you need is 2 sets of hpi 6mm front shafts and 2 sets of hpi hd lower shock caps. the glitches come in the form of the stock piston. its fits fine, but needs to be shimmed. our piston is thinner then hpi piston, so the lock nut doesn't tighten down all the way, just a few small washers.
the front shock shafts bottom out on the shock cap. not a problem on the tt, but the mt does(wheel size).. its fixed with eather hpi shock body or rear redcat shock body mounted up front. the other problem is with the lower shaft end. its shorter the stock recats, so when you put the (lower)spring retainer on, it hits the suspension arm cousing the spring to rub on the shock body. its easly fixed with a spacer on the bottom or by dremeling out a small "U" shape in the arm. its not a problem with alloy arms. there is a few threads about the hpi's if you use the search key. you can do all 4 shocks for $62.00 us; i'll get you the part numbers.
