shocks
yellowjacket45
my shock came apart today while running, I had just tighened them before i went out to run, what are you guys doing to keep them from unscrewing, I thought abought ordering another set of spring collars and use them for a jam nut instead of lock tighting them
If you are talking about the spring coller there is an aftermarket set that has a screw in it so once you set it you tighten the screw to hold it until you want to change setting. If you are talking about the shock cap I use a socket on the cap and a rag and pliers on the body and so I can put a little more tension on it.
