Side pipe or rear pipe
tracker ryan
Junior Member
Well all: :) ;)
Have two minds will I go for a DDM side mounted dominator or
A rear mounted Baja 5B/5T tuned pipe it seems to not have a specific name part#87401.
I guess it all comes down to power across the whole rev range with least amount of bottom end lag ????!!
Any thoughts
The dominator is a much better pipe. It will really make a big difference. Your truck will come alive.
Sound RCCAD
Tryin to see what kind of other bodies would be a good fit for the MT I`ve heard the stock one is poop ?????
The side Dom has the bleed exiting the side. You would have to cut for that. The Jetpro is narrower and that fits better it touches but if you use some heat tape on the inside of the body you will be ok.
