Silverback Beadlocks
spike.1965
northumberland
Hi there, I have purchased a set of silverback beadlocks inner and outer. The outers are fine but the inners seem slightly too small to fit my wheels. Are the beadlocks wrong or are the wheels wrong.
may be that your foams are to large which will cause your rings not to line up accordingly. You can always trim them with an exacto knife if that's the case
Are they the nylon King Motor beadlocks? I just swapped a set out to a different color, and they are kind of a pain in the rear. You have to do a lot of finger gymnastics and tugging in order to get them on, it almost makes me miss the days of simply gluing tires on.(almost)
Never had an issue with Silverback fitments and i've used them on all my cars (baja and Losi)...best out there in my opinion..
