Trickle007
Contributor
I have a slight crack on my CPI pipe right at the bracket that mounts to the motor shroud. I cant see the crack/hole but i do get oil comming out of the crack, not alot but enough to notice. Would this crack effect my tune? because at max RPM sometimes the rpm's will completly fall off for a split second and then come right back again does not do this all the time it is very speratic and only at max rpm. The carb is an Walbro 813 and it on a Mt Rampage.
