Snappy rc
rob1
When venting the tank do I need to trim one of the fittings I have never used the snappy rc kit any help would be great also I only got 2 brass fittings is it best to use 3
When installing the gromet for the snappy fuel kit do you need to enlarge the hole in the tank having trouble getting it
Nope. It's a tight fit.
Use a bit of 2stroke oil to help. Also, install it with only the pickup line installed.
agreed its a very tight fit but alot easier as rcdad stated to put oil around the rubber and only the pick up line installed in the gromet once installed it will help also on the other 2 lines if you cut your fuel line on the end at a small angle then the point is easier to slide in the gromet. Put oil on the ends of the line also.
