I have welded them together and it works great. In fact, I really question RedCat on why they do not produce a 1 piece pinion shaft in the first place. Mine used to wobble horrible no matter how tight I had the grub set screws. This two-piece shaft on the Rampage was not engineered well. It is that simple.
Here is what I did to ensure it worked when I welded them together.
1. I ground the ends of each flat side at a 45 degree angle so that the when I welded it and then ground the sides flush again, there was still a lot of weld left for strength. You have to grind a channel for the weld to penetrate, otherwise when you grind the sides of the hex shaft flush so that it will fit back into the aluminum brake disk holder, the shaft will fall apart under a load. I tack welded one side and then trued it up using a razor blade to make sure it was true.
2. I kept a cold wet washcloth wrapped around the pinion at all times during the welding process. I did not want the pinion to heat up and lose its hardness.
IT WORKS PERFECTLY! the shaft, gear, pinion all now rotate precisely without any wobble or lose grub screws. It takes some skill and time to ensure it is very close to being true, but is really worth it. Now I NEVER have to check my grub screws on the brake block any more! Many MCD cars have a one-piece pinion, so I knew it would work. It does. The entire drive trane runs smoother with this mod. But if you do not have good welding, fabrication, and grinding skills, I would ask a machine shop to do it for you. And tell them to keep the pinion covered with a cold wet cloth during welding.
Redcat needs to design a one-piece pinion shaft for people without welders! It is that simple.
