Some basic Questions about basic stuff
tresnsom
Hi everyone,
Questions I have are:
  1. When going to slightly taller gears with say 4.5hp engine with 8000rpm clutch, should you change anything about stock clutch?
  2. If you go from 25:1 with regular oil for break in and switch to a 28:1 synthetic oil, how should you tune the high and low needle compared to regular 1.25 and 1.5 turns open from manufacture recommended?
  3. Easiest way to dry wet foams in tires without taking apart and letting them air dry?
  4. What are the best foams/Tires for off road and separate set for on road ( 2 sets) that wont grow in size at top speed?
  5. How long is it safe to go top speed back and forth on straight line before you do damage from running car to hard if your running safe tune?
thanks everyone!!!
