KrashKrieg
I used a durafix generic brand called 'Aluminuweld' and got a great start to a cage mocked with 2 curved bars (front to back) and screwed to a board to hold in place...I 'welded' the six points that the 3 cross bars used, let it cool an hour, dropped it with the board 4 feet high and all joints busted off!
There is no way this stuff is strong enough tp hold the joints together, it doesn't BOND with with AL. All it gives you is a strong surface weld even using MAPP gas (burns hotter) instead of propane.
I will probably need to mock it all up, number the pcs and have a friend of a friend TIG it together. Durafix is a bust as far as I'm concerned.
