alfred e numan
- Reaction score
- 0
Hooked up a new Fly-Sky FS -GT3B. Used the Reciever that came with the radio. Everything checked out fine, Steering, Throttle, 3rd channel kill switch. However, I did not test turning off the transmitter with the cars electronics on.- this would have been a dead giveaway that the something was wrong with the transmitter. The car lost its signal, went wide open. Gald the hsn was rich to the point of not reving out- No steering-throttle-no 3rd channel. All i could do was watch it head across the field and clip a big concrete barrier. Opon returning to the shop I thought- I should have just turned the transmitter off- Well, I tested this on the work bench. This made the throttle go wide open. I tried binding up the supplied reciever and 3 others to the suspect transmitter- No cigar. No bind occured. Hooked up the old transmitter, Everything checked out fine- When the transmitters power was turned off with the cars electronics on, the throttle servo did not go wot. kill switch operated as intended also.- Its gotta be a bad transmitter- What do you folks think?
