chitown joe
- Reaction score
- 1
i was at work, we don't have any big machines for milling or anything, just a band saw and a drill press,but lots of metal stock.
i decided to make a spare tire mount, i grabbed the smallest aluminum bar stock, measured the holes out and drilled away,i recessed the old wing mounts so i would not have them in the way of the mounting, i had some old extended shafts left from upgrading from the e-clip type, drilled it out but left 1/4" inside for mounting,added a bolt and nut it was done, i drilled out some material to make it lighter,since it was a big piece of alloy even if it was the smallest we had,
came out pretty good just a bit on the thick side material wise
