spark plug and ignition coil for GAS 30 CC HY 2 STROKE ENGINE
barun mukhopadhyay
Junior Member
INDIA
Hi
I am new to gas engine . I have just bought a rampage xb with 30 cc gas HY 2 stroke engine . What type of spark plug is required ? an ebay link is enclosed
http://www.ebay.com/itm/140675555884?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
rampage part no 3066. pls give me rampage part no and if possible , ebay link .
Also , the ignition coil part no .
For fuel , 75% no lead or low lead premium petrol will do ?
for lubrication , 25% 2stroke engine oil as used in schooters , will it do ?
Kindly help
best regards
barun
I don't know if they have auto zone in india. The spark plug is a nkg cmr8h(a cold plug) or a nkg cr7hsa(a hot plug) You should be able to get these plugs from most auto parts stores. the mixture is 5.12 oz of 2cycle oil to 1 gallon of 87-91 octane. Hope this helps.
Well .20-.25 is good.I would lean towards .25,others may lean towards .20. I better get this straight the smaller the # the hotter the plug,#7 is hot.The larger the # the colder the plug,#8 is cold.All around a #7 is good.
