tsudo5th
What outside temp should I use a colder or hotter plug? Which is the hot and cold plugs? A good plug gap would be? Ngk, champion or other bran better?
NGK is good.tsudo5th said:Ok so ngk plug I should stay away from?
Ditto, definitely a well made plug.RCDAD said:NGK is good.![]()
You don't have to swap the plug according to outside temps. I run the same plug all year long. The lower the number, the hotter the plug and vice versa. Plug gap should be around .020". I've ran both NGK's and Champion's. Didn't notice a difference. Both are great plugs.tsudo5th said:What outside temp should I use a colder or hotter plug? Which is the hot and cold plugs? A good plug gap would be? Ngk, champion or other bran better?
There are many...rev9fan1 said:does anyone know the ngk part numbers for the temp range for the plugs?
