Spark plugs?
kaztheminotaur
What spark plug comes with the Rampage
What other plugs are people using? I assume that different plug will vary the spark intensity?
Well Since the cage was a afterthought in the design if you run the stock cage plan on running the stock short plug. I am working on a new rollhoop to run the irridium plug.
Lasts longer that is it.
Iridium is a denser material so the resistant is higher, at the same time that what makes it last longer.
