Spark plugs
Noodle ed
uk
:helpsmilie:Got A BLACK end on the plug what should i do
also is there any equivalent plugs to the CMR 7H
thanks
thanks
Check out this: 2-stroke plug colors
Your plugshould be like the last one.
You may be slightly rich if it is black. What are your settings at?
T check your settings:
Find the L & H screws on the side of the carb. They will say L or H. Insert your screw driver into the end of the H or L screw. Turn the screw in until you reach the bottom making sure to count the amount of turns the screw goes in. DO NOT Overtighten the screw. Count the total amount of turns in then back the screw out the same amount of turns to return it to the same setting. The amount of turns is your setting.
The CMR7H crosses to a Champion RZ7C.
