Spectrem DX3s WITH TELEMENTRY
hyper 78
nottz.
High guys,was looking through an rc mag today and saw an advertisement for the above mentioned tx.It looks great and with a price tag of £160.00 ,seems to be within my budget for a nice transmitter.I actually read that it displays and records your revs and speed etc as well as temperature,there is a nice display of a tachomoter and digital reading for mph!does anybody have any experience with this piece of equipment as i am always interested of the speed i am going amost other things when bashing.As it can read the engines revs i suppose it means that i could rely on it for tuning my hsn.would it work as well on a 2 stroke as it would on a nitro/brushless? i UNDERSTAND THAT IT WORKS WITH SENSORS for the readings but could it be that accurate? For instance is the vehicle is wheel spinning or larger tyres were used would that give false reading,surely some sort of gps unit would be more accurate as time and distance is the formula for measuring speed( i accept there are also variables to consider when working out this way)Maybe gps would be more expensive.Anyway i think it would be a cool piece of kit to own, what are your views?
i run this set and to be honest as i can the handset is great easy to use good for the money and very light,,the telemitry is not that great the temp sensor works well but ive never got the rpm sensor to work as it should,,,,and there not the strongest the wire break easy and now i don't bother with it,,,,mine also came with a extra rx which im saving for my on road project well worth the money loads of people don't rate the range but mine seems ok and i can go further than ever before with the sanwa gemini 2 and the range on that wasn't bad
yes i have the gemini 2 amongst other txs and they seem to have good range without lag.how do you rate the speedo on the dx3s?
