Spring kits
airtimegrafix
Hey guys I’ve got a ? Bout spring selections for my 5t? So I’m lookn for a spring kit that has different upper spring and lower lower rates for the rear! And same for front? I’m pretty sure the front has just a single spring but would like to dual rate up front!
Don't bother with the Integy kit. The springs are all to close in spring rate. I think IRC and Taylor might have some heavy duty options if thats what your after. Mcmaster might be an option as well.
I don't know why you would want dual rate up front, seems pretty pointless to me.
Ddm makes stiffer springs which I liked
Lookn to make them an actual dual rate shock! If you look at a Trophy truck you’ll see a cross over ring that stops the spring separator at a certain point! So the softer spring is for light hits ect. Then when the separator stops at the cross over the main heavier bottom spring takes the rest of the hit! Cause with the two springs without the cross over spacer they both collapse at the same time! Therefore it’s not an actual dual rate! That’s why I was lookn for different springs to actually make it more adjustable
What your looking for is not out there bud. Not unless you have your own made up. The baja shocks are not and have never been great. Most anyone serious with them will replace with IRC or LOSI 5ive shocks.
