Thanks Imadman.imadman said:these Cheapest And Easiest Thing To Use Is A Piece Of Solder, Then You Can Use A Caliper To Measure Your Squish. Other Than That There Are Gauges And Stuff You Can Use But They Are Not Cheap.
You're talking about 'quench area' and trying to use a tool that screws into the spark plug hole? I doubt you are going to get an accurate measurement.max 1 said:Dose Any One Now Wher To Get A Squish Clearence Tool.that Screws Into The Spark Plug Hole.
Ahh, solder. Good idea.IMADMAN said:These cheapest and easiest thing to use is a piece of solder, then you can use a caliper to measure your squish. Other than that there are gauges and stuff you can use but they are not cheap.
