Stalling out
Boriqua935
I have a Rampage pro which has 2 1/2 tanks through it. I also have a killer bee kill switch installed. Yesterday while running, the engine was running fine for about 15 min, then it began to stall when at standstill. I was able to restart and run but again stalled at standstill and could not restart. Any ideas here? Bad spark plug, clutch bad, bad ignition wire? Any help would be great. thanks
I believe the problem has been resolved. I drilled a bigger hole in gas cap, cleaned plug which was black and leaned out both L and H needles just a bit. I also adjusted the throttle srew. Ran almost a tank and she's is running sweet. Now that i have the 813 on order she will hopefully run even better. Thanks for everyones help. Like I said I'm new to gas, but learning fast with all your help.
Glad you've sorted the prob, but watch out for the 813 as it injects a small amount of fuel every time you blip the throttle, if your on and off the throttle all the time this can result in flooding, you may be better with the new 990 which is simiilar to the 813 but without the accel pump. if you do need to tune the 813 only adjust in tiny turns in or out. just my 2 pence with mate. ;)
