Start issues
IAMTHETRAPP
Active Member
My xb won't start at all. It ran and when I turned it off to refill. It hasn't started since. Any suggestions.
Check to make sure you're not flooded, then check spark.
As andyken also said, if you're running a kill switch, make sure that's deactivated. I did that once and pulled pulled pulled until I realized the stupid kill switch LED was flashing. I forgot to deactivate it. Duh.
Also don't be afraid to pull the pullstart of and check for debris... Had grass get into mine and wouldnt let the magneto create spark... Check by leaving the plug in the wire and rest the plug bottom on the cylinder head, pull the pullstart and look for spark.. Probably not the case but had me stumped this evening lol
Re: Start issues
I had grass get all over my coil and caused ny rig to not start so I got a slammer Damn and haven't had that issue since
Not to get off topic, but, is it ok to run without the stock plastic head cover, the piece that holds the kill switch, and goes around the plug? I've yanked mine and duct taped the kill switch into the slot just to test it out....
Re: Start issues
You can run withought it but from my understanding you will need airflow over the head and the fan won't be directing the air over the head
Ahhh...i see lol...guess i better put it back on, just had the thought of how itust be holding heat in, didnt even think about the fan...me and my bright ideas lol, i definetly don't want to cut the stock body up....
