clean it, of course by slipping i assume you mean the starter pawl is either not fully engaging or even moving out towards flywheel at all. clean it with compressed air and a brush then use some dry grapite lube (available from auto parts stores and locksmith places) on it. now if you take the ps off and find broken teeth on the flywheel you will need to replace that but seeing as you said "slipping" i am assuming you just need to clean your pullstarter assembly.
I should elaborate that it is not the pullstart assembly. I use a rotostart type plate. It's a lot less complicated: just a socket on the outside directly connected to an engagement cup on the inside.
The problem is somewhere in or beyond the flywheel. I'm not familiar with the assembly of these engines at all.
EDIT:
After typing the above, I thought I would go find the assembly instructions for the drill quick-start. It's not as "direct" as I thought, there is a one-way in it. I guess I shoulda know that. I'll dissassemble/clean/lube the starter and chime back in tomorrow.
ok well in your case then i would say it is the one way bearing. if you have ever had a nitro engine you might have come across where the pull starter or electric start wouldnt work (same thing as what you are running into basicall) the oen way bearing gets fouled by debris be it oil, or dust, dirt, and grime and it will cause either the slipping you describe or the other end of the spectrum which is it would lock up adn in your case i think a clean and relube would get you taken care of.
looks like you found your problem. i personally will stay with the PS myself :lol:
Nope! Too many painful years with them. I hate'em. I like play with out the pain when it come to R/C. I'm just going buy a couple spare shafts.
