Starting problem baja
rajsbaja
I changed the air filter to ddm billet n pipe to don V1. Can't seem to get the baja started any help pls thanx. :(
check and see in your getting spark and fuel and set the carby back to factory settings H 1 1/2 L 1 1/4 turns from fully in
thanx can u tel me if i may be missing a rubber oring and their may be an air leak. since i removed the original air filter two rings were there one small and one large but i didnt put any back is there any diagram where i can see. thanx for ur time,
i hav tried everything in the book it dosent start. the plug is very slightly wed do i need to increase th lsn. or what do i do, hav only done some 6 tanks on the engine. any one pls help.
