I have replaced the Carb with one from DDM (Walbro), running a jetpro pipe and some other small adds to replace the basic parts that will need replacing. I have a 1/5 scale HPI 5B right now and never had an issues tunning or breaking in the buggy. On the MT, that is another story. I have put a new gasket where the exhaust header meets the block and also used gasket sealant on all areas to ensure no leaks, the carb bubble is not leaking, so it is holding the fuel mixture. I originally had it started with the choke closed and tuning the idle, which was pretty basic. I have the choke open and it will start but it is very hard to keep it going. Sounds like it there is too much fuel but after fiddling with the carb I am confused, lol. I started out with resetting the carb back to zero on the L and H needles. I went out about 1 1/2 on the L and 1 1/4 on the H, could not start the MT for 30 mins. I went out almost to 3 turns on both and it start with throttling the transmitter wide open and it finally caught and started, but I had to keep the throttle at 1/4 to keep it going and if I let off it would die instantly and sounded very bogged down, like maybe there was too much fuel. So i started tunning the card on both the L and H needle in to lean it out. But I am having a very hard time starting it every time. I checked to see if fuel is flowing, it is cause I was able to run it for about 5 minutes in the yard. I have tried priming the bulb before starts to ensure the fuel is available. I have removed the fuel line to see fuel flow, no leaks I can see. I have a small oil buildup around the Spark Plug, but very limited. Since the MT starts but then dies, I know the Spark Plug is still working. I have about 1/10 of a tank used, so still extremely new.
Any help would be great, just at the point where I am frustrated. lol..
-R.C.
-R.C.
