Starts, idles, but wont move when given throttle
chefjness
Hi Gang,
Kind of have a mystery here. On my MT it starts perfectly, idles wonderfully but when I apply throttle it goes no where. A topical exam showed nothing. When I rotate one tire they all move. I was able to grab the clutch bell and rotate that and it moved all wheels. This led me to think my clutch shoes were worn out but when I opened her up I have like 90% shoe life.
Any other thoughts?
Cheers,
John
does the motor really rev up or does it stumble and just go know where? check the square drive behind the brake set-up. there is a set screw right behind the gearplat on the D-shaft that comese lose. can you hold all 4 drive gears and still roll the truck?
KILLER.....Just after I posted this..I was staring at the MT and found a missing set screw...
just like krypto thought!
Cheers,
John
here it is....
/monthly_2009_08/583c605a5f56a_missinggrubscrew.jpg.b4b01a983fce046c961a2f634986b177.jpg
forist said:
Don't know about u guys but I used red locktight this time on mine. It keeps coming out with blue. :(
thats probly not a bad idea though i would be worried about getting it out. once out of frustration i put red loc-tite on my MT wheel nuts. now thats dumb! it was like a circus act trying to get them off. busted a rim.. :D
a cap screw would be good. you can give it more torque with a larger allen key. tapping it would be esy and you could notch out the d-shaft. im fine with mine. i give it a twist every 2 or so tanks. the others don't come lose
