steel spur gears
Agree (mostly) depends on if you use more for road use, and or on/off road.
If road use, then any bearing grease will work fine. I use a ptfe based (food grade) grease, that is quite expensive.
But I get my cars to 100mph and faster.
My off road stuff, no I do not bother with grease (as long as the correct mesh is done) you should be good without it.
