Steel spur?
tizdaz
Sunny Northwest!
hi guys :)
ok since ive had my MB (about 4 years) ive always ran plastic spur gear with alloy carrier & steel pinion. Ive only just replaced the plastic spur (after almost 4 years!) with a new one as my old one had seen better days ^^
anywayz ive only had the new one on about 3 weeks (less than 4-5 tanks through it) but after today it looks worn already!? ...but ive also just fitted DDM Dom pipe (torque) as until now ive never had a tuned pipe... so im guessing the extra power/torque is just ripping through my spur?
The mesh is good & runs freely so its not that, not too tight or lose but after today its already showing signs of wear...so ive decided to maybe go for a steel spur which will give me an all steel setup for the gears this a good idea?
Ive never been a fan of all steel gears as i prefer to lose one of my stock gears than pushing damage internally, but i don't fancy shelling out £10-15 every couple of weeks for new spurs :(
If i was to go for a steel spur the one ive seen is this one for £30:
but what carrier would i need for it? as at the mo i have this carrier which is no good for the above gear:
ta lads ;)
I run all steel and have no problems,they are just a little noisey when you start to roll to a stop,go for the steel;)
will do ta mate :)
don't suppose u know what carrier id need for the gear above?
like i say at the mo im using stock spur wit alloy carreir so the gear above wont fit onto my current carier, i guess i need one that the gear bolts onto ?
hi guys :)
ta lads ;)
Isn't that top pic a diff gear.
had a look on ebay, none there :(
there was a all-in-1 spur on there a while ago but i held off & got another plastic, wish i never now! :(
think im defo gunna go for the 1 piece one rather than carrier.
Trebor - where did you get that one piece at?
Michael there are several guys here that make them..this being one of them
http://cgi.ebay.co.uk/STEEL-GEARS-F...sGames_RadioControlled_JN&hash=item255b510250
as you can see he machines the flats onto the gears bore.....this is ok as long
as its a tight fit if not then:2guns:your gonna get wear from the constant
back lash no matter how little that will be......my gears have 2 grub screws
with green loctite you can never be to carefull:lol::lol:
