Steering Knuckle Bushings
pfrederi
Does anyone know where I can get the Steering Knuckle bushings to fit the Rampage MT? Ive been searching rampage shop and rampagetoys and only find the bushings that fit the other models not the MT. My bolts came loose and the bushings fell out. Searched local Hdw stores to see if i can find some but they don't have the right fit\size. Its the insert that goes in the knuckle and the bolt to go thru that allows the knuckle to rotate. Im driving with just the bolt exposed and its chewing up the aluminum steering knuckles and creating a lot of space causing the wheels to start to wobble.
Any help is appreciated.
Thx
Thx
Hard to work out what you're looking for.
Do you have a pic?
Thx
Did you try to email Redcat? They may be able to help you. You may be able to find a flange type bearing to fit in there if you measure the size needed with a digital caliper
Are the knuckles stock or after market? If stock you should be able to order them from redcat if there after market you'll have to go to the manufacturer of the part.
Thanks guys. I asked redcat and they said they dnt sell the bushings seprately. They said I would have to purchase the part number 050005 to get the four bushings\sleeves. Guess thats what ill have to do themn because i cant find a substitute but thx again for the input.
