steering problem
Abz
New Member
Hi guys,
I have a rovan 30.5cc. Thevsteering has stopped working and its fully charged I don't know what to do. Is it servo or battery or transmitter. Comments please.
more than likely it is the servo. A quick way to test it is swap the steering and throttle servos at the receiver now your throttle will control the steering servo and steering the throttle. If steering still does not work bad servo. if the problem switches to the throttle servo it is a bad radio or receiver. Good luck hopefully it is the servo because sooner or later it will fail so better to replace it now versus the radio and then servo dies.
Another Problem
Hi Mate,
Thanks for your help and feedback. I opened the battery pack and it turned out the fuse was burnt so yeah I was lucky in that sense but know because I had to remove the throttle/brake lever to remove battery pack, after I refitted the throttle lever when I turned the engine on the engine idle is to high and when you lift the back tyres off the ground the wheels spin so Im thinking the lever needs to be adjusted. Can I Please get your advice and recommendations.
Thanks.
Abz
