Steering problems
Erik J.
i just bought a savox sv-0236mg steering servo but when i put on the throttle the wheels pull straight.when the wheels are in max angle the servo still can rotate a little bit. And when i steer to the right or left when i pull the weels straight the servo doesn't move but the arm where the servo is connected to does.here a picture of the part that still moves but the servo doesn't.
Does anybody know what the problem is?
it doesn't slip. I set the end points of the servo so when the wheels are at the end point it doesn't go further.but when i pull the wheels straight the part with the spring in it can still move.
what is a servo saver?the piece with the spring can still rotate when I steer so the Wheels go back straight when I hit the throttle
u really shuld get that fingerscrew on the servo saver (the one on top of the spring) as long dawnwards as u can, when you turn your wheels that servorsaver will flex alot with the screw and spring that loose
