Steering servo and arm
Dvmnn
New Member
I want to swap out my steering servo from a km to a hpi but I have changed my steering to symetrical which needs a full/double arm. The servo is 25t but and heres the problem its output spline is a larger dia than standard approx 8mm instead of approx 6mm. Where can I get a larger servo arm. And how will I know by a description that it will fit the larger spline.
Count the teeth on your servo and get corresponding size arm (ie: 15t or 17t etc. Or you can look up the servo and see size,that info is usually given by manufactures.
A lot of arms also have the # stamped or printed on the arm somewhere.
