G
Guest
Guest
If you are talking about the futaba plugs (black), you can either replace the plug on the switch or get a new switch.
After comparing the specs on the turnigy 1270HV and the Hitec 5765 i would think that the turnigy has the better specs as far as having more torque, but the hitec wins in speed and since it is half the price of the turnigy it would seem like a very good option.redthomas said:I use a turnigy 1270 hv or something like that on my xsc. Even with the stock battery it yanks the bigger ruffriders I use. Its actually the same physical size unlike the hitecs being a little smaller
I run the 5685. It's a great servo. No problems to report.BountyHunter03 said:ah overlooked that little detail. Well crude, is there a 10th scale server that can handle the 7.4v? What does everyone else use with the killer bee lipo? I ordered the 6000mah from killer bee yesterady.Found the HS-5685MH- it looks a little longer in height than the stock one but says its 1/10th application and not a bad price. any thoughts on this one.
Thanks for the info brother!RCDAD said:Most LEDs can handle 12v. I run the Killer RC lipos. You may need to trim the side tabs in the box. Do that and they fit great.
