steering servo
2Fast
Minneapolis
Tried the search option with no luck.
What is a good steering servo for the 5SC ( I have a clone made by rovan rc)
it hasn't gone out yet but want to plan ahead. inexpensive is Ideal.
Go with a dual servo kit and use dual Hitec HS-5765 servos.
Note: my goof, the above should have been a reply for a Losi 5ive setup - not HPI 5SC. :)
The costs of having 2 servos at that price is at the high point of having to spend that much,and I do not know how to set up duel servos.
5sc.. I think he meant a Baja,, not a losi,,, never seen a dual servo kit for a Baja,,, one hitec 5765 should be good, and you may need a hpi radio box ,,, the clone servo mounts don't fit standard servo,, my km servo was rounded on ends,, I would check yours,,,, find darksoul meaty mounts to use with stock hpi radio box,, to stiffen it up,, or use the new ddm servo mount,,, I believe will fit hitec servos,, just not savox,, they are larger,,,
My km radio box has uses rounded servo but my rovan radio box is more squared 'ish servo so do some research on the hitec servo beforehand for whats needed. ;)
Good advice and good catch. I had just read a similar thread about the Losi 5ive-T and obviously it was still stuck in my head. 5SC is certainly NOT a 5ive-T. :D
