Steering servo
You have to cut the nipples off the existing mounts, fill in the lower screw holes with jb weld or 2 part epoxy then drill new lower holes for the screws....the stock servo is wider than the hitec5745. With the alloy mounts I had to file a notch for the wire to clear on one mount and file a bit of a flat on the inner curved part at the top for the servo to fit inside...don't know if you have to do it with the plastic ones.
im not running hitech's, but they are the same size. i didnt have to shave the side like moo. just trimmed the "tit" and poked a new hole. i trimmed the BOTTOM hole to keep the servo off the chassis so its not sitting in water and mud..
