rampage idiot
I need some opinions, I am running a rampage mt ver 3 with stock mt wheels and tires with dual steering servos in your opinion if I upgrade to a hitec 5755 do I need 2 or will one do the job. Thanks
Will the 5805 fit on the xt? Is it stronger?Deluge said:You could run two 5755's, or you could try one 5805. I personally don't like dual servo setups, too much of a hassle. I run one 5805 with the Futaba mount, and it gets the job done.
Here you go.the1320god said:Deluge, u got a part number for that futaba mount?
Do run the 805 with mt tires cuz that's what I plan on running? I luv those tires lolDeluge said:
There are a few X series owners who run the 5805, so it'll fit. The specs are pretty much the same as a 5755.savagekiller said:Will the 5805 fit on the xt? Is it stronger?
Yep. I run the MT tires.the1320god said:Do run the 805 with mt tires cuz that's what I plan on running? I luv those tires lolSent from my DROID RAZR using Tapatalk 2
The 5805 is bigger than the 5755. Other than that, they're pretty much the same.Cajun said:so what is the difference between the 5755 and 5805? I am about to pull the trigger on buying the hitec 5755mg for my XT
