steering to the right weak/no steer
cranedoc
Junior Member
I have a Red Cat MT and ran 1 tank of gas thru the Truck. The Truck steers good to the left and very weak to the Right and sometimes no steer to Right. What do you guys think, Thanks.
Sound like the trim could be off or your EPA which is adjusted by the DR knob on the stock controller.
steering weak to the Right
Thanks for the info RC Dad, found the problem. The Plastic arm that hooks to the right side servo was loose and wiped out the splines in it. Can I get alum replacement or should I just go with plastic?
The aluminum horns are better but I don't know of any that fit the factory servos.
