Stiffen suspension
Dieselaw
Chandler az
I read through some posts to try and find my answer and never really did. So....i want to adjust the stiffness of the shocks on my redcat chimer. I am just not sure if i need new shocks or if i can increase stiffness with different shock oil. Im just starting to look into this so any tips will be appreciated. Thx!
you can tighten down the preload collar for some stiffness - but you will still bottom out on big jumps.
Heavier shock oil will definitely do the trick. I run 50wt in mine and wish it was stiffer on the big jumps.
You need heavier oil. Try using 35wt.
I don't like very heavy, too heavy and you'll break your shocks. And from my experience, heavy oil will turn the car into more onroad.
The shock's aim is to absorb the impact as much as possible without damaging your car. 40 wt on the xb with MT shocks was undrivable on a bumpy terrain.
Changed to 30et at the moment, and I think it is best all around
Baja springs for the rear come in as double springs(tall and short) you install them on top of each other.
The front springs come in as one.
There are literally many combos you can choose from.
You can run front soft on front and front hard on rear
Front soft on front and rear hard on rear, etc..
DDM has a lot to choose from
See here: http://www.davesmotors.com/Search-Page/?search=spring
