people around here say the redcat tuned pipe is not much good, so I still think you should start with a better pipe (like the JetPro), seems like the easier way. As for the demon tranny, I'm also going to get it (if they ever make it again, seems like it's been out of stock since forever) and I'm gonna get 2 sets of gears. The cost is low enough for the extra gears to make it worth it imho.
One more thing: if you want more low end torque and don't really care about top speed (or the other way around) you can play around with the gears a little bit to get it closer to what you want (swapping the 29 with the 31 or the 26 with the 24, depending on what you're trying to obtain). Each of these will get you around 15% improvement (and obviously 15% loss on the other side). Another advantage of this is that doing this, you can simulate what you're gonna get from the demon tranny, by looking in their table of speed ratios. Switching the 26 and the 24 will be pretty much identical in terms of launch torque to what the 1st gear of the 36/20 setup would get you, which is listed as "Very high torque comparared to stock"
