stock gearing with g320
berto1230781
Hey guys what's the best pinion gear we can use with the stock spur gear using the g320 also what oil in the center diff should be used to stop the front end from unloading so bad
What are you going to be doing play or Raceing for me it's total setup to stop unloading front end
I run 100000 in center diff
50000 front diff
30000 rear diff
and red springs all the way around
1.9 pistons and 40 front and 50 rear weight shock oil
On fast tracks it's a good set up it won powerjam and motor broke at east coast Nationals
As for pinion iv not run this motor but I'd start with 19 that's stock if you do not notice clutch fade after about 5 to 10 min of running try 20 from what iv heard it has a lot of tork so if you wanting speed and are playing 20 just watch for clutch fade
So a 20-21-22 should be fine with this engine and what motor inserts should I use for then. You think a diff locker is a good idea?? I just run mine on the street and grass
