stock servos
bajamaniac69
Florida
I was just wondering if the stock servos on the rampage mt really that bad???
I was not going to be running to hard with truck.....probably 80% road and 20% dirt..........will they last a while or do I need to chang them out right away?
Thanks
J
stock servos are fine. use them until they break. i just had bad luck with the inport servos in the past and replaced them before that became and issue.
I'm impressed with the steering servo so far. The throttle/break servo although metal geared is a bit slow. I had the white wire come out of the throttle/break servo in the first 10 minutes of running the buggy. I replaced it with an Airtronics 94357 servo. Maybe RedCat will replace the throttle/break servo for me?
The steering servo is on par with the HPI baja servo. Actually think it is a bit better. I'm keeping it in the buggy till it dies, if it ever does.
I replaced the throttle servo right away, but i too am inpressed witht the steerign servo in the MT, it will almost turn the tires dry.
The 945 has pretty good specs;
Class: High Torque
Digital: No
Programmable: No
Voltage: 4.8v or 6.0v
General Specs:
- Bearings: Dual BB
- Gears: Metal
- 60° speed: .16 sec @ 4.8v
- 60° speed: .12 sec @ 6.0v
- Torque: 122.00 oz/in @ 4.8v
- Torque: 153.00 oz/in @ 6.0v
-- 1.60 x.80x1.50 inches
- 2.00 ounces
Applications:
- CCPM Helicopter
- Competition Helicopter
- Competition Sailplane
- Competition Airplanes
- High Torque
- Off-Road Car
- On-Road Car
i put a Hitec HS5745MG servo for the steering and a Hitec HS645MG for the throttle and brake. Great responce.
well I just wanted to know....I can get a hitec 945mg for 50.00 shipped or a hitec 645mg for 40.00 shiipped thru tower hobbies.
Which is the better deal????
Thanks
J
