pwaicon
I have an MT from the first shipment, where the shock shafts used a c-clip to retain the piston instead of the washer they use know. So far the shafts have held up with no issues other than the c-clip will only last so long, I am using the HPI clip, then it breaks and I have no dampening. So I decided to order me some replacement shafts that use the washer instead of the c-clip, this is where my problem starts. The original shafts on my shocks are different than the ones I ordered. My front shaft measures 89.12mm and the replacement shaft (50121) measures 94.29mm, the rear shaft was 94.88mm and the replacement (50122) measures 99.92. So I have question for you guys who have the newer shocks, do your shock shafts go all the way inside the shock body when fully compressed? I ended up putting the front replacements into my rear shocks, but this leaves me with no replacements for the front shocks.
Also, is anyone using the Redcat piggy back shocks and if so how are they working for you. I am assuming they use a washer and nut to retain the piston, if someone could verify this that would be great.
