Check out KillerBee's site, good videos there and help, or go to youtube, look up Squirell's videos, he has one on kill switches also, good luck Bro![]()
I've got engine problerms. Engine will not start however kill switch is okay (Normally Open) push in and closes killing engine.... However I'm getting continuity between the live (red) and neutral (black) through the coil?
This is inversely not correct but this is the 2nd could only on my 4th tank of fuel, I have a switch blade fail safe could this be causing the coil to go?
Also getting countinuity between live (Red) and neutral (Black) on switch blade kill switch is this correct?
Have tested everything sepratley ... Also getting a good spark but not kicking in as its grounded (countinuity between conductors) ?
Any advice would be appreciated
Thanks Kieran
