strange leak, help need
ika
Hi,
I need help..
What is the source of this leak, maybe exhausts gasket ?
its Redcat Rampage MT.
Its my first gas engine and i am not familiar with inner parts.
Can you provide link of gasket?
I checked and found exhaust bolts were loose. So maybe it was a problem...
Is there any way to stop loosening exhaust bolts?
Some will say to add some threadlock.
Problem is, heat is one way of loosening it!
If the thread is good, and the bolts worn, I would suggest getting new bolts, which would be a tighter fit.
Don't FORCE them, as you could snap the bolt or damage the block.
There are various high temperature bonding pastes which may work if the thread is loose.
Dwarfy has a lot of experience in these things. If the 'simple fix' of a spring washer works, its a cheap fix and worth a try. I would check the bolt wear 'though - costs relatively nothing to replace them at the same time.
Al.
Clean it real well which it looks like it needs then start it and see where it is leaking. Being up so high my first guess is exhaust gasket or header to pipe seal.
Exhaust bolts was loosen.
my solution
attachment.php
