Preacher
- Reaction score
- 22
I took my KM Baja apart for cleaning for the season (didn't touch the front steering or suspension, just removed the fuel tank and radio box on the front end. When I tested the steering I noticed that the right side hub is hitting the top of the bottom A-arm and binding up. I also noticed that when holding the front end up in the air (without tires) that the right side suspension is hanging lower than the left side (the side that is working properly). If I lift the a-arm by hand until it is level, then the binding does not occur. I didn't disassemble the front end at all, so I'm at a loss as to what could be the problem. I need some guidance so that I can fix the problem.
