stupid radios.
Mister Insane
Junior Member
so the other day my brother took his mt for a run , and after we started it up after running for 5-10 min the steering servo would not respond to the radio....wtf... so we bound mine to it and ran it for awhile and it happened again to mine , the throttle works, and the trim for the steering even works but it wont turn using the wheel on the radio... plz help
First verify that it is not the TX or RX by plugging the throttle servo in the receive slot where the steering servo used to be. If it works then it's the servo. The steering servo's go really fast. I gave away two of them that have never seen a single volt through them. They just go out to fast.
What radio are you useing? My steering servo went out after only 10 min of run time on my TT. That being said the stock servos on any thing out of china should be or needs to be upgraded cuz all the manufactures put in the cheapest servos they can to keep cost down. Your not alone with this problem,the other thing that will kill your servo is leaving the radio on without using the servo (just letting it sit) cuz were useing big recver batterys(5000 mah).The servo motors burn up.
thanks
no its not the servo its the radio i tried the radio in my dunerunner and it didnt work either
Yeah... The receiver's can be a little sensitive sometimes... I had the same problem with my FlySky receiver.. (when the ESC went up in smoke.. it took out the receiver..) I just replaced the receiver, and bound it to the Transmitter... problem solved.. (7 bucks to fix it)
