Superbee voltage cutoff for a 7.4 volt LiPo?
bonefish
How many volts should I set the cutoff with the dip switches on a Killer RC SuperBee Kill Switch? I have a 7.4 volt LiPo in my rig. Thanks,
Thanks, I just got done running it before I got any responses and had the Superbee set to factory settings. 4v and 1 glitch sensitivity. For some reason the truck just dies after about 5 min. of running. I thought it was that the idle was set too low so I increased it. But that wasn't it. The only thing I can think of is that I'm running around powerlines and the glitch sensitivity is shutting off the engine. I'm going to increase the glitch sensitivity to 3 and see if that helps. Thanks again.
I don't think it is the Superbee kill switch, because I loose all power to steering and brake. Including engine kill. I thought it was the on/off switch on the MTXL. I sprayed it with some CRC Quick Dry Electronic Cleaner and it made my run last a little longer.(20min) before total loss of all power. I jiggle the on/off switch button and then power restores. No loose connections(wires) on the switch. Do you think if I contact Horizon Hobby, they will send me out a replacement one at no charge? I only have 3 tanks of gas run thru my rig. Thanks
Horizon Hobby treated me good too . MY mtxl piston ring was broken would not start they sent me a new top end. No questions asked. Im very happy with there customer service. Glad they did the same for you.
