Switched to baja bow ties on my mt...where to buy new gears
Hondarider290
Junior Member
Would like to switch to the 27/33 gearing on my mt now that I have the bow ties ....can someone give me a link on where to purchase these...and I want steel ones if that is at all possible
I took mine apart last night...it is the four pin style...so where do I buy them from now that I know what they are?
Is there a way to convert to the square...can I just buy new hub things that bolt onto the spindles that the gears go on? Thanx for all the help by the way
Thanx again for the help....would you recommend me getting a belt drive system instead of the gears? I know you sell one and a convesion kit so I can run it...what kind of gear ratio does the belt kit have....I want a good setup for all around bashing...a decent amount of low end tourqe but I don't want it to top out within seconds...I trust your opinion rcdad so just be straight up and tell me what you think would be best for me...
I ran 29-31 gears on my MT before the belt drive. I run trenchers on my MT which are a little taller than the bowties. I run a 7500 rpm clutch spring to help get it off the line quicker.
The 1-1 ratio of the current belt drive is similar to the 29-31 it would be 30-30. If you run a good tuned pipe this works great. The 1-1 ratio was designed for the buggies which run wheel/tire sizes similar to the bowties.
If you are running bowties the 27-33 will top out quicker than 29-31 and still might be a little on the low side for that size tire/wheel combo. Every basher and racer alike have diferent driving styles. I should have all my planned ratios for the belt drive sometime in March. The belt drive has cool factor to it as well as its benefits.
If you want the 29-31 gears you can get those here for your 4pin set up.
http://www.nitrorcx.com/51c00-054110.html
Hope this helps.
You've been a tremendous help...thanx a lot....I think I will go ahead and order the gears...see what I think then pick out a belt drive system after I see what kind of ratio I'll be happy with...cuz it'd be nice to have a belt drive and have a set of gears for spares. Just in case...
gears 27-33 or29-31 4 pins for rampage mt pro v3
hi sorry for my anglish
i search transmision gear 27-33-25-25 or 29-31-25-25
for my rampage mt pro v3!!!!
in the site on your furum is back order !!!!!!!!
i wait for 5 month and its back order
please help me used or new i don't care
p.s its 4 pins gears!!!
ty
firecat :)
