Taking out the front wheel drive????
rcspeedmart
Atlanta, GA
Is taking out the front wheel drive on the dune runner will it mess up anything? What would be the difference in the older 2 wheel drive that redcat sold and you can buy a 4 wheel drive conversion for it? I would like to make the dune runner 2 wheel dive because that's what more people have at the track and they are going to stop letting the 4 wheel drive run with the 2 wheel drive. Thanks for any and all hep.
Deluge said:
It'll be fine. I'd take out the front, center dog bone and the axles.
i dissagree i own a dunerunner and when i snapped a center dogbone pin i ran it rwd and ended up snapping a rear pin too within a few minutes of driving, if you arent hardcore bashing it you should be fine but if you want to run rwd i would upgrade your rear drive cups and dogbones
krashkrieg said:
Just pull out the front dogbone and VOILA...FWD
Well it will be more then just pulling out the front dogbone I will remove the front drive bones and cups the front 2 wheel dogbones and take the front diff out also to reduce weight.
Where are there pins in the center dogbone???? I just have cups and dogbones.
