Tarmac busters " BUSTED "
Go fast
Miami
Like the title says and only after 2 tanks of running them , maybe it's more the inserts than the tire. I need a stronger on road tire/insert for high speed runs. Actually the KM all terrain tires that the buggy came with are awsome and hold up to all I can throw at them , just did'nt want to wear them out as I mostly run on asphalt.
Another thread for the same problem? Why you gotta' go making multiple threads about the same thing? Then you go and blame the foam failure on the tires, epic FAIL!
If I were you, I'd just buy another set of rims with those KM tires you like so much on them. Then you can run the old tires on asphalt, and save the new tires for when you're running in the grass or dirt.
If you just have to eliminate the tire expansion at high speed, there's really only one way to fix that. Hostile belted slicks, but at $70 for a pair of tires, without foams, they're not cheep.
Epic fail ? :lol: Oh and I think you meant to spell " cheap "
